In need of Help..
So if I did go for discs on the rear would I need to replace the master cylinder & add a booster ? Thinking about the comment from AusBucket I may have to change the master anyway...
Did you change the master i think i need to replace mine also just worry about matching whats there
I did put in a new master cylinder but it was exactly the same as the old one.. Napa matched it up no problem for me..I will change the whole setup when I get around to a rear disc conversion but that has taken a back seat while I make a few changes elsewhere..
