Questions reguarding steering brackets and shocks
I have approx. 1000 - 1100 lbs. on the rear axle and use 180 lb. springs.
I would move on and sort it out after the car is assembled. The stiff springs will be good for hard launches.
Maybe put a nice strong tray under the bed box that you can load some lead weights in to smooth it out. ;)
I have 165lb spring on mine. Its brutal at times. Car is 1800 lb total but not sure exactly front to rear distribution. I have 150 lb ones in my summit cart, just waiting to make my mind up.
Mine has 12in 125# springs in rear ---ride very nice and handles very good. You have to preload it some .
No matter how much you preload it it is still 125% spring until it coil binds . Don't think a Tbucket will every get to coil bind that spring .
My shocks mount at about 14 in that 12in spring mounts easy . QA1 part 12CS095
Good luck
SRM1952. Im tossed up between 125s and 150s. That's why I haven't ordered yet. That and lack of time recently.
