Those are the guys whose posts I read and it helped me out quite a bit! Another might be the Bob Hamilton DVD. I used his ideas to widen and lengthen my body. Prior to that I'd Never worked with fiberglass before. (Hope it holds together!)Awesome! Thanks, WM!
I'll expect to see some entries from DonnyRay and Choppinczech in this section.
I didn't know and better when I lenghtened my body so I used epoxy resin. Same goes for when I widened it. I later learned that it is a bit stronger than poly resin for what I did. My nephew has recently started working at a body shop and is learning fiberglass repair. He suggested that I cover the areas that I split with woven cloth over the existing mat to increase the strength. When I'm ready the underside of the floor will be covered with a layer of woven to tie into the sides. Hope I'm doing it right! What do you guys think?Hi CheapT thanks for the compliment . I learn from Choppinczech & you tube videos. RE : Lengthening body parts. Use EPOXY resin (it's stronger than polyester resin).
