If you take a piece of conduit and play with it, with nuts tacked in and ends screwed into them, or easier still, lay it all out on either a table with paper or cardboard?? anything that will be the length you would like to see on your T. use a thin piece of wood, drill a hole in each end at the desired tube length, put a nail either up from the backside of the card board to let that frame end pivit, put a pencil in the other end, now with any angle you like the looks of for a staring point, move the rod up and down the amount it will travel while the car is doing it's thing. You will see (the pencil lines from an arc) just what moves and where and how much. If the rods are pointed up from the axle, you will see the exact travel this way. Now You can make up your own mind as to how You want to mount them, to the look You like... Good Luck with your project
