Adding L E D lights [taillight , brake & turning lights.
Does anybody know where I can get my hands on a wiring diagram for wiring up the following.....
Speedway led taillights/brake lights -3 wire
LED front turn signals -2 wire
Simple on-off-on switch
I have a resistor for each of the LED lights.
I'm trying to incorporate it all while using a PAINLESS KIT #10308.
This wiring is not my favorite thing to be doing.
Thanks,
PaulR
First thing is always to acknowledge those that help you along the way .......
PotvinGuy and Ellis8500 were a tremendous help with my wiring project !!!
I've been reading this thread and thought that my wiring project might be over kill for this situation. But just maybe there is something that be gained from my diagrams.
Below are my wiring diagrams for LED lights. BTW, I did not use LED for the headlights, but I did for my rear lights and front turn lights. It seems that all is needed for LED Turn/Signal lights are a LED flasher, therefore you don't need resistors in the circuit to make them flash appropriately.
If you want to download the dwg in a PDF format, then your file is below......
  • HeadlampCircuit04.pdf
