fordsbyjay
As most of you probably know my car likes to dart around sometimes which makes for some exciting rides. I am going to change to hydraulic shocks but I wanted to see if changing the drag link and tie rod to a large diameter would make any difference. My car is a Total Perf. car and it uses wimpy little 1/2" rod ends and 3/4" tubing for these two components. When I go over bumps I swear I can see the right wheel flexing all over the place. I had a look at Speedway motors and they use 5/8" rod ends for their tubular steering components and 11/16" for their tie rod ends. I have some 5/8" by 3/4" shank teflon lined Aurora rod ends so this is going to be the basis for my upgrade. I spent all day driving around looking for tubing only to realize some people don't know the difference between tubing and pipe.
When I was a couple blocks from the house I figured I would try this little machine shop as a last effort. Met a nice guy name Chad and after discussing my goals and looking through his steel rack he suggested some solid aluminum bar. He had a bunch he purchased for a different project that never happened. He kept talking about how cheap it would be and in my experience cheap is a relative term and I am apparently cheaper than most retailers think. LOL. So after asking several times about the price he just gave me 10' of 1" solid aluminum bar. I am not sure of the grade but how could I pass that up. My crappy day just turned to a ray of sunshine. The whole 10' piece is considerably stronger than the 4' piece of tubing currently on the car so I think it should make a big difference. Thanks for letting me babble on and I will keep you all posted.
