I absolutely HATE doing brake lines! Uggghhh! I can rebuild engines, build race cars, sheet metal work, body & paint, weld, blah blah blah, but for some reason, being able to create a simple leak-free brake line connection seems impossible to me. Why is it so difficult?? It's not rocket science!
I have tried three different flaring tools and they all butcher the flare the same way. I'm lucky if I can get two out of ten connections to not leak. I always make the line a little long so I have room to cut off the botched flare and try again, over and over. Man is it frustrating! Even the banjo bolts on the calipers are leaking. There has to be a better way do do this!
I have avoided buying the super expensive flaring tool because I would only use it once every ten years. Plus I know people that successfully use the one I have (though I've also read they are crap)...I guess it's hit and miss...
Someone needs to invent a fool-proof method for making custom brake lines...
Sorry, rant over...
Sorry, rant over...
