Using a socket around the e brake cable to compress those spring metal fingers is sometimes helpful to remove them.The rear brakes are done, got new parking brake cables installed today. I forgot what a pain it is to get the old ones off the backing plate.
Lol! Guilty!On the opposite side I used a small hose clamp to compress the metal fingers, and it popped through the hole. The first side, I did it like a caveman.
I agree 100% on using the mechanical brake light switch!Don't know if the parts store will have exactly what you want. I went with the Speedway purple one on the rears & it did the job. Also, I recommend the mechanical type of brake switch. The pressure ones tend to fail at the most inopportune times. Like at the NTBA Nationals in Springfield (I won't mention any names!)
View attachment 14835 View attachment 14836
