Carb Issue
Must of done something right then, it does happen occasionally ! ;)
I, out of desperation, used JB Weld to block off the vacuum passage on the bottom of a Rochester 2 g carb to adapt it to run as the primary carb on a Pontiac tri-power set up. That was in 1989. It’s still as I done it today... As long as the base part is clean and porous, so it can get a bite, J.b Weld is good stuff.
