thanks for replyWelcome from Oklahoma. Does it have a catch can for overflow? Sounds like the cap isn't lettng anything return.
I don't think that kind of radiator has a pressure cap. I know the one I got from Speedway has a solid cap with a pressure relief valve on the bottom tank going to an overflow tank. That's what I have and haven't got that far in my build yet so I can't say how it works.
Gary[/QUOTE
hi gary
when I first started the motor there was no problem.
all sudden top and bottom hoses collapsed after cool down .
speedway rad .has no vent. pressure valve leaked from beginning so I changed spring inside
so I pluged it. today I drilled a 1/16 hole in the cap.
I think that solved the problem .
garyI'll be sure to make a note of that since I'll be running the same setup. Thanks chromeman.
No. I built the frame and everything but the front axle from scratch using CCR's drawings. The body and 90% of the rest came from CCR as well. The radiator is from Speedway though and a few other parts.I'll be sure to make a note of that since I'll be running the same setup. Thanks chromeman.
i don't know if that is the correct thin to do !If your Rad has a relief valve on the bottom to the overflow tank, the over flow tank should vent to air. Maybe your relief valve is not working and by drilling the hole in the Rad cap, you may be hiding the problem and not fixing it. Just a thought.
It may not cause any issues, just keep an eye on the coolant level this summer when the temp is up... I drill vent holes in gas caps to allow free er fuel flow, but that’s a little different. If it does allow it to lose coolant, maybe a expansion tank would work?i don't know if that is the correct thin to do !
but now i have no problem.
there has to be a way to relieve the vacume.
