Cutting a flex braided radiator hose?
Kurt64
I bought a flexable braided upper radiator hose for my T but it's too long....about 6 inches or so. If I cut that much off, it will be back where the spiral groove and spring are. Will it still deal if I cut it that far back? My opinion is no, but anyone ever done this successfully?
[QUOTE="Kurt64, post: 209239, Will it still deal if....?[/QUOTE]
Sorry. Will it still seal... I hate auto-correct
No ! But you have options 1- find a shorter flex hose 2- find a preformed hose you can cut 3- Napa carries a formable flex hose that's consistent size that can be cut ..go back to what you took off ....
No problem cutting spring. It just keeps hose from sucking shut.
I was actually talking about the hose itself. With that spiral groove going the length of the hose, I was unsure if I could get it to seal properly under the hose clamp .
What was on there leaked. The guy that had it before me used a 1.75 ID hose on a 1.5 OD pipe by adding another short piece of smaller diameter hose between them....it didn't work very well.
That's how those work , when you buy those they come with adapter sleeves that you stack , a friend's started leaking and we used pieces of radiator hose. For sleeves 6 or7 years ago....
ORF , I believe he's talking about one of those universal flex hoses that hand a straight collar on each end..
