I am in the process of going through the brake system on my T so have a few related questions. My T currently has a single-feed MC purchased from Total Performance about four (?) years ago. I've never been able to get a complete full brake pedal so am planning on a few changes. The brakes are drums on all four corners so I'm not sure if this MC was the right one since, in hindsight, it appeared Total Performance mostly leaned toward discs on front and drums or discs on the rear. So here are my questions:
1. It's my understanding a dual-feed MC is recommended over a single-feed MC because if you lose one wheel cylinder with the single-feed MC you lose all brakes. If you have a dual-feed MC and you lose a wheel cylinder how will you know? Is there a different braking feel, do you install idiot lights like on new cars, just watch for a puddle of brake fluid or...?
2. Is there a standard dual-feed MC I can purchase that will work with the four-wheel drums? How do I know which one to purchase?
3. I have 6-7/8" of space between the MC mounting plate and the trans mounted cross-member. What is the length of most dual-feed MC's and will I be able to get one that will fit in this space?
4. I am going to install a 10-pound residual valve in the rear circuit (close to the MC) since the MC is under the floor and I want to do all I can to improve the bleed. Any reason not to also install a 10-pound residual valve in the front circuit too?
Thanks in advance for your advice.
Bruce
Bruce
