Front end parts
Dan Noecker
I made a fixture to hold the front end batwings to the axle for welding. I had all parts polished. After welding the chrome shop will spit shine things and then do the chrome work. Just in the polished state they do look pretty good.
Chrome doesn't cover anything. What ever the item looks will be the same only rust resistant. You saved yourself a lot of money!
Nice work. Gotta have those little jigs. I have a big pile of them.
Thank you for your comment, Ron. Do you do custom work? I have in mind an idea for my rear radius rods. I could fax you a sketch of what I would like so you can see. I appreciate it.
Dan
Nice work. I envy you guys that can make your own parts. Keep the pics of your build coming. Love pictures.
Ron did you forget my perch we talked about?????
Yes our fax # is 865-933-1131 it is on 24-7. Looking forward to it.
Hi Ron,
In the pics I have enclosed you can see I was going after the 4-bar setup in the rear. What I was thinking about doing different was to cut the lower bar and having it mate up with the upper bar so it is like a regular radius rod set up. That is what I wanted your opinion on. Do I go with a regular radius rod setup, or keep the 4-bar that you see in the pics? I would appreciate anybodys comments on this.
I, too, much prefer a four bar set up over a radius rod setup. It allows the front axle to travel up and down in a vertical path whereas a radius rod allows the axle to swing in an arc. but if you like the old time traditional look, go with the radius rod set up.
Unless building a traditional period correct car, I'd stick with the 4-bar setups. As mentioned, a bit better ride and handling, plus less twisting of the chassis.
Of course, your car = your choice.
I like traditional looks but I also like doing something that helps ease the ride a little. I am tending to leave it with the 4-bar setup. I do appreciate the comments. My front axle and batwings are in for welding and then its off to the chrome shop to finish things up. I will post a few pics when I have a finished product to show.
"I" beam axles can twist a little where as the tube axle can't. If you have an I beam you can go with either/or but with a tube, you'd be better off with a four bar.
Hi Ron,
Should be able to make that, for you.
