Gary49 building my first hot rod
The posts are from CCR as is almost everything in my build.
Cool. The reason I asked is because CCR doesn't offer the slanted posts. Did you modify them?
As luck would have it, I got lucky and ran across an older pair from them from when they did.
Lucky dog.:D
I have a pair of Total's slant windshield post(not installed yet), yes it seems to me like they lean back to far. I have a stock windshield post and frame (25??) that I'm thinking of taking a little pie cut out of them to lean them back just a little.
Yup, 30 degrees is a tad too much. Looks like modifying is the only choice, now.
me to. There is a thread on here with pics and details
G
Can't find a way to look for threads I started, so it will be a search to find that threat. Trouble is, no idea what I called it.
Found it but no pics showing thanks to photobucket
Windscreen brackets, simple to make
Gerry, you should see if can recover those pics. some how... This should be a tech article!
Got that add on, so not sure why the pics don't work????
