Sure,
Let the headlight wire from the first pull switch go to the common on the floor switch, which will then select the hi/lo connection to the headlights.
Nothing wrong with it, just a different way. Works good if you don't have a lot of foot room.Something wrong with a floor mounted dimmer ?.....
Run the parking lights on the dash lights, on all the time. Then run the low beams where the parking lights would normally go, and run the high beams to the head lights. So first pull turns on the low beams, parking lights and dash, second pull turns on high beams, parking lights still on. Now do away with the floor mounted dimmer switch.
I'm no dummy. Got "Draw It!" at the Dollar Store.That must be some sort of Microsoft CAD program.
Yes, it gives both close and far vision on High. The exact pattern would depend on your reflector and lamp. Easy to try and see if you like it.Interesting idea. Do you do that Potvin? Does is work well?
Well, when I got it home, it was just a sheet that said "1) draw it yourself, 2) scan it and 3) post it."PotvinGuy - "Draw It" at which Dollar Store?
