To be up front for those that are unfamiliar with my situation, my build was cut short by health issues...almost certainly permanently. I still play around with the plans and what-if ideas just to have something to do.
One of several unconventional aspects of the plan was to be the use of many of the components and the geometry from a Fox body Mustang racing triangulated 4 link rear suspension...but with air bags and shocks instead of the stock separate coils & shocks or the racing coilovers. One aspect of the plan I'd not worked out was the frame mounting points for the shocks...or if I skipped the air bags, coilovers.
The typical Fox rear shocks mounted vertically, with the lower loop axis parallel to the axle, and a threaded shaft on the upper end. I'd hoped to keep the stock axle mount...but the upper mounting was going to require custom fabrication no matter what. The shocks I have and intended to use are PRO SM600s with loops on both ends. The questions come from the orientation of the shock loops. In my mind, with both loops parallel to the axle, given the articulation of a triangulated 4 link, that orientation would introduce a lot of binding. To me, turning the shock shaft and upper loop so that the axis is around 90 degrees from the lower may help the binding during articulation and is the best compromise. Yes? No? Seriously No!?
How about if double loop coilovers are used instead of conventional shocks?
Just one of the multitude of things that make me go hmmmmm.
