Jarrett's 27 roadster
You don't need expensive chemicals, let them soak in a bucket of Pine-Sol.
50/50 mix with water,, the stuff is strong.
I let my carbs soak over night, the next day the crud just wiped right off.
WOW ! This is educational. Today I used cooking oil to remove roofing patch ( tar ) from my hands. It worked great ! When I was a child , I used the original worn out rings for cleaning the grooves ( my father was a mechanic ). Time marches on.
I also have a pitman arm for a vega steering box ( it's a straight arm ), if you are interested let me know.
  • Like
Reactions: RPM
Jarret, I have a terrible memory did I send that Flaming Steering box to you several weeks ago. I was planning on it but this Old age thing is getting old...….
