I don't know yet.. I guess I'll find out as I rebuild..Do they need reaming after fitting???
Ron of course is correct, they do need reaming.. I got the new bushings in ok & I'm just waiting for my reamer to arrive.. The hard part for me is having to wait for the tops of the pins to be chromed.. Could be 4 weeks... Can't wait to get them back..Do they need reaming after fitting???
I thought about doing that but just about everything else is chrome so I decided to keep it the same.. It will cost me $50 to get the two tops chromed along with the two felt pad cup washers..pins to be chromed.. Could be 4 weeks.
Could always just turn up a cap and stick it on. Done in SS and to the same design as all the other fasteners on show.
Blank on the right with recess for KP head
My parts are already in the chrome shop but I will certainly consider this IF there's is a need to do them again..That's a whole lot of money for those chrome caps! If you did turn a couple of caps from stainless you could polish them to look nearly as good as stainless. And they will never rust!
I ended up finding a local machine shop that could line bore them so I had them done..The service was fantastic.. Had them back the same day..Can you post a picture of the reamer you are getting, as it takes a special reamer to do it correctly.
If they go in the bushings go with you it!
