Ladder bars
RPM
Administrator
Forum Sponsor
Here are the adjustable ladder bars, we are selling these for nostalgia Gasser guys. They will work in a bucket also. $259.00 and they are available in different lengths. All of the hardware on these is 3/4" instaed of the 5/8"
WOW! Those look majorly beefy!
Ron, will those work with rod ends and a 3/8" thick bracket, instead of the parallel brackets?
I just ordered rear radius rods from you, I think they shipped yesterday. Kinda wishing I woulda seen these first.
Ron, what are the dimensions of the radius rods? Mainly, the through bolt holes, front and rear.
Wow....... I was so stoked, I didn't notice you had wrote that already. Thanks.
Ron, I have an installation question concerning mounting the rear end brackets. At what degree would I set the inclination of the brackets? Would the holes be 90* to the ground, since they are adjustable and set the pinion angle when I get everything installed?
Yes set the brackets square to the ground, you adjust the link to rotate and get your pinion angle.
Sweet! I like it when I think I have stuff figured out, but I require validation from those with the knowledge. I should be calling you in a few weeks.
