No, I'm not stupid enough to build a car with no brakes, the ones I have aren't working properly.
This set up is all new parts - everything. The M/C and pedal assembly is Speedways under floor kit, Dodge rear end with standard drum brakes (everything replaced) and new Disc/rotor on the front. 2lb (front) & 10lb (rear) valves installed in the lines, All new lines, no leaks.
The problem is the front disc brakes are very weak. There is some stopping power there but very little. The rears I can lock up if I really step on the pedal. The front not a chance they'll lock up. Nothing is seized in the caliper - pads move like they should.
So that's where I am. Any ideas on where to look?
