Phantom T
I will be following along with this build RPM is the kit I want to get too.
I'm still in hunter/gathering mode. I will say what I have received from Ron to date is very good quality and you couldn't ask for a more friendly customer relation. I hope to get started soon, right now I'm just kind of dinking around powdercoating small parts and going to be priming some larger parts. For the chassis and suspension parts I will be using Eastwood DTM (direct to metal) epoxy primer and Eastwood rat rod satin black urethane paint. More to come.....?
  • Like
Reactions: RPM
Still scrounging parts........picked up some bearings & rings. Winters coming soon..................001.JPG
  • Like
Reactions: RPM
That's just plain hot rod porn. What man doesn't love a nice, smooth rear end.;)
  • Like
Reactions: RPM
Managed to squeak a few engine goodies in with the xmas stuff. Santa needs toys too! 15492355_1378186402193484_1252609222578978691_n.jpg
Never built one before. I've done fords & chevys(gen1) f4, f16, A10, b52, and f15s though, so I'm sure it will be fun. The 6 bolt mains are unique. It's an iron block but I doubt weight is an issue in a bucket ;-)
Couple more engine goodies. Almost time to build the engine :)001.JPG
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,700-6,700,
Intake Duration at 050 inch Lift: 219
Exhaust Duration at 050 inch Lift: 228
Duration at 050 inch Lift: 219 int./228 exh.
Advertised Intake Duration: 267
Advertised Exhaust Duration: 276
Advertised Duration: 267 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.525 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.525 in.
Valve Lift with Factory Rocker Arm Ratio: 0.525 int./0.525 exh.
Lobe Separation (degrees): 112
