Poor stopping power.
Thanks Dave, when chaning the MC, for the brakes, I found that I can lift the body up about an 1" 1/4. I can see 1/4" thick round rubber, it looks as though they're torn, or ripped. I'll check on replacing them..Scott
OK, it's on my list. Just so I know, is this an issue of braking efficiency? Is the applied system pressure different between the two reservoirs? If the only real issue is reservoir capacity, I won't have to do this right away. Capacity is only an issue when I'm bleeding the brakes.
Jack
Yes, as I understand it, its mostly about the volume as the discs require more than drums. I'm not sure of the internals, piston size etc
