We just spray the regular primer on bare wood and then color and clear. Your color coat for single stage or clear coat if you use base/clear should seal the wood just as it supposedly seals the steel. If you use one manufacturer's primer and then another's color/clear the paints might not be compatible and could craze. Don't ask me how I know.
Just remember that not all resins dry completely when exposed to air. I did a trunk lid once that appeared to be completely dry after a few days and so I shot primer on it. I set it aside and didn't get back to it for about 2 months, but when I finally got it out again the primer had crazed and had to be sanded off. I'm just glad it didn't have the final coats on it or I would have been redoing that as well.Thanks for the suggestions! I think I'm gonna just seal it with fiberglass resin, sand it and prime it.![]()
Very true. You said "then you have a chance of sealing it up", emphasis on the word 'chance'.you can't "seal" wood w/just a coating [paint , poly , whatever} just ask any wood boat owner... if you oncorporate some f/glass cloth into the eqation , then you have a chance of sealing it up...wood swells & shrinks w/ the weather & age/exposure & will always eventually split/crack a coating ...
Choppinczech, do you have any words of wisdom pertaining to the epoxy? I just ordered some to use on my door and jamb edges. Everything else is polyester resin and glass. Does it flow out and adhere well to existing resin based parts? I haven't personally used it before in this application.This epoxy works well for sealing wood also.
EPOXY RESIN WOOD METAL PLASTIC HIGH STRENGTH GLUE MARINE GRADE FOOD GRADE 32 OZ | eBay
You are right about resin curing. I've had issues in the past when doing General body work and the resin will bleed through, etc. Even through primer and sealer. I had a fiberglass header panel on a t bird that the exact replacement wasn't available, a mercury panel was the same except for the emblem in the top center. I had to fill a hole. I had a fit trying to get rid of it. I reworked and repainted it three times. The resin kept showing through and outlining the repair. I ended up cutting it out and using stranded bondo. Grrr! A easy three hour job took the better part of a day and a half. And yes, it was a favor for a friend....Just remember that not all resins dry completely when exposed to air. I did a trunk lid once that appeared to be completely dry after a few days and so I shot primer on it. I set it aside and didn't get back to it for about 2 months, but when I finally got it out again the primer had crazed and had to be sanded off. I'm just glad it didn't have the final coats on it or I would have been redoing that as well.
