Progress
Pushrod
I made some progress tonight, installed the spindles and got the rear radius rods attached, coil overs are next when I get the chance. I need a couple more jack stands as you can see...:laugh:
I like the paint can usage. I'll bet we all have done that a time or two. They seem to be the perfect height!
Looking more like a roller every day! :thumbsup: Do you have hardware for chassis/steering links? ie: drag link, tie rod, panhard bar(s)? I see a front panhard, but not in the rear.
Spanky, no drag link or tie rod yet, are they usually a custom made item? I have a panhard bar for the rear.
Yes, because every setup is a little different. Once you get it all mocked-up, take your measurements for tie rod and drag link.
I got the rear together, the panhard bar brought everything into adjustment....except the position of the photo.
Looking good. Every little bit brings you closer to the day when you can take it for a spin around the block.
