Purchased TP 23 T bucket from seller brakes not right
Scott Hamilton
Front discs brakes not correct for 4 bolt spindles with Airhart 175s. Only inside piston pad connects. I believe that the caliper float is not setup correctly and he bolted it directly to mounts. I'm trying to find the kits for the Total Performance for the 4 bolt spindles. found them at wintec fabications but reviews and phone lead me to believe out of business. Anyone have an idea were I can find SPINDLE MOUNT DISC BRAKE KIT FOR T/P SPINDLES or some replacement floating calipers that can be bolted solid and have the sliding pins built in. I'm looking at Wilwood 120-1064-P Spot Caliper as a replacement but think I'll still need to adjust the mounting to allow for float. Hope this made sense as I'm new to this.
scott
