Rack & Pinion Steering Conversion - Need Help
rbsWELDER
I want to convert my T to R&P steering this winter. I have seen many pictures of your conversions, but has anyone every seen a step by step guide for the conversion?
Thanks,
Yep. do a search...
LincolnuT has a nice Unisteer setup. You can probably find a picture of that if you are interested.
I have R&P on my roadster but have very little spring action. If you have much spring travel you may experience bump steer. Also I am running a dead perch setup which lessens movement.
Mark I do not know of a Video of a Unisteer like I mounted on my bucket which is a true Half Rack. Not a R & P set up, but I have many photos I will send you if you want to look at them. Some of them are posted on this website & the NTBA website. Like Windy said the only real thing I was told was to keep the shaft to the front steering arm to be as level as you can keep it. That way you should be ok......Let me know...…….
As I mentioned, do a search on this site.... all the advantages of RnP and retaining the correct look of a T. Putting one across the front x member or chassis, kills the looks, at least for me it does. Especially when you can do it the way the pics above show. Just a little more work and engineering.
Gerry that is some nice work, but it is on the wrong side of the car, me thinks...…………LOL...
I put the R&P in the crossmember:
u9o_P8KRztQMyUEf1OjI-yUcGkg8V3VFikY55jYLNcYh7r3OrliW84hFx82HjO0AxMfyIfY7IkraVtBCYSLoVJnTYDUW8Uu-Vm5aQw9Wr9NsIVCbRWAO-K8LSFrS1tEro7aRwwgVKY5WpVuX-0Y-yNGvR9IyY8CdTZAeuKWJr84vOaBGYH6K4MZF0m-81KW9nFYYy-I-u5i1tOvGgPJmuKvRsdSi2po8A1zY0Y9xV9jO5Ikwra6FMPKH4SOwVGUnNh5l0e_-3_tKMQiZQ8p7ZtB9Mno_uyWErIGWyx4K08C5A9zT_sQiH9oA8QzPawySK2s5el_4vcFJeKjBF6XkpwG3ke-WsgofM5WAoq8uvtnAzTxIIeT1j74WCWcQNwDBQAwOvjez-xb5CcHLvdgNb1lbyIKeRwYnWvIt1Dr_Folv-JswIpiurWvB4N-NMxTWXk3tsWigSCtvDbKM9PQappKdZca4Q1ehymEqVxZE0EP4mifUkbRzfUrj8TvgEzT5gV3PiEeJg-OYgwCLKIOYzUc-Ix92VRIdGAMPIu2KSeAAmFAB92P0FmpVI3GmtrXHILjOfznX-0gazgRp7YRd3JkJGhpStGHkhtJdd-tpFheV7TwSvrPb4jnj9VSpr0npTaZQ-phTXaLC1mC_v168NIHd7tYTC-kNWpvGHjzu9t-e_NCgC1uCmKzlHzw0wi9ZLdAVYSJpU17eNw3jZ6jzAtS0=w894-h330-no
....steering shaft runs next to frame rail to a double U-joint to the steering column.
View underside:
q5Ew_h6DmeCICFblQSrZNumB-ohvMNHNbN0LMVNywUGsMmbxkiU0gqn5Sy7gR_gFAz49MjJiqEnVBSyHbU7EN8IZYxJrZtN4qgfDZyjxzPlLteH8EjelwrQb0D7vDHs8TWHopH8-vWR-koZHb_mGcFP73harM9vN9mlRD4yH5rOhyMVlzJtsjKhRH8mJagfqf3X6zPDmIPNbNBnZS-XV_mCIyK9SsR3lip9ryegYCppAHGUNVi0yYycthosFplIXDzQpYW124k3eOzc00Xvhkg4uZW9A-qMcR9ww-LNGtQTi3EML8hz1gB68Tl0pixwNkWznGdu8SOrH_dLfkVPUXZmCSsP3MRRqxQL-brkYk4ZTH89vqPDUPLKBDtXYYkfR3CwrQCsfQuqCXFWfBfntGGooEfdlE7rQoUPJy0vlwfaU6myylolIxPZ2SlQJMLIf1c-Gaz25MrFoWDq2huhmhRtg6u5ywb0CRm7qZl_E8tFNOZdh7AiLQ-OvcfqjzH1Y5cYZOr11BZgV0uSWvIGmAozQmjTOfumxx5zeBiSnGb3VmcMOZAe2MbRiPMOvGKYYiy2bwvFraTnO1KBR2iKZ2EEkm-8a42VZDVObrAOB3V8sTHfczcfvr69JizPcj8N3WLKsC9PHBf7vhaFpDu34p5XBMRGmlnoO35KfA2jm9lrr2_iLPC0QxAkn-6IB6d5J96Y6zEBBhrNt7MGHUTDq93Lk=w1052-h789-no
