I have old school motor cycle spoke wheels on the frt. with no brakes and would like to run GM single piston calipers on the rear. Any one tried this? I got this car in pieces but it appears that this is the set up that the previous owner ran.
Years ago I built a '76 Pontiac Ventura. It was a v6 auto car and I frame offed it, put a built 455-4 speed in it, frame ties, etc... It had front disc brakes, I put the most aggressive metallic pads on it that were available as well as semi metallic shoes on the rear. Around town or normal type driving it was fine, but if I got happy and let her roll, it would scare me to death trying to stop fast. From over 100 to about 60 it would respond well, but then they would heat up and seem totally ineffective. There were times where I literally leg pressed the brakes, pulling on the steering wheel. I ended up redoing all the brakes on it. From then on, I built the cars to drive, not just go fast. I'd hate to destroy a prized build over inferior brakes.Add space...drive defensively...give yourself lots of room.
These T buckets are sketchy enough in traffic. I don't have the guts to leave being able to stop in time to MY planning and the other guys willingness to play by the rules.
They are all distracted idiots driving fast, responsive cars with multiple safety features and very effective brakes. They will get you eventually...and you will be at fault...or hurt.
Maybe both.
My car was built with no front brakes. It stopped.
Not effectively...but it did stop.
Previous owner tried to power brake it the first day out...slid past his driveway and almost into an intersection. Lots of noise...not much stopping.
He added front brakes and drove it all over the place with no worries.
I've made some changes myself and now it stops even better.
Still not as good as a new car due to the skinny fronts...but at least I feel like I have control.
Your car...your choice I guess.
