mikesplumbing
Hey everyone, I've been looking and researching for my build and can't seem to put it all together in my head. What my son and I want to build is a basic non-stretched 23 T-Bucket using a 327 4 bolt main I have in storage, nothing real fancy I guess.
Anyhow, it seems like I have all sorts of options between the frame and the body combination but what is considered standard? Maybe I should break it up into two parts.
First is the body, I see that some bodies sit on top of the frame but most sit into the frame creating a channeled look??? I would imagine most of the fiberglass bodies out there were cast or patterned after the original and therefore the distance between the frame pockets are all similar?? I'm having a hard time connecting this together in my head, does the standard channeled 23 T Bucket non stretched body have a standard width between centers?
Second part is the frame. Youngsters and some other frames out there seem to have the frame rails running straight with no taper, I think I remember it was always called a pinched frame? Anyhow, on the straight frame type doesn't the outside dimension have to remain the same for most bodies available? On Youngsters plans the width is 23" to the outside, but on some others it seems wider, so my question is what fits what? How can a 23" frame fit on a channeled body? From the picturesI see on the forum the fiberglass has a pretty tight fight on the rails as it comes out on the firewall so my thinking is it has to be pretty exact right?
For you guys following Youngsters plans what 23-T body fits the 23" outside dimension rails running straight? Sorry for all the guestions on something that's probably simple but for some reason I just can't seem to make sense of the frame to body relationship.
Thanks for the help
Mike
Thanks for the help
Mike
