s10 front brakes
Francis Blake
I hope I can do this, maybe someone here knows. Will the brakes from a 1991 s10 fit any spindles that are used on tbucket front axles. Any help will be appreciated....:confused::D.......Francis
Well, yes and no.
No, you can't just put the rotors on any spindle that I have seen used on a straight axle.
Yes, you can get a kit to use them on the ford '37-'48 spindles. Speedway has a kit that you can get 2 ways, complete or brackets and bearings. It sounds like you may only need the kit to use what you have. That one costs about $125
