I tried that spray foam thing. It did not set up very well right at the mold line but good around everywhere else. ???
Oh man. Sorry it didn't work out. I've done the same method with body filler. Build it up with layers and add a block of wood to hold onto on the last layer.
You guys are pretty enginuitive with your sanding tools. We used to keep all sorts of different shaped things to sand odd shaped areas in the shop, wood mostly, different sized dowel rod etc... Some good ideas here.
I used to keep different colors of primer just for that purpose, I would thin it down so it wouldnt build up and clog up the paper, just use it as a guide. Works good. This stage does make a big difference in the finish. I also have several lengths of blocks to get flat areas as strait as possible, those areas show work or lack of it when you look down them, like hoods, or the side of the car.I'm right there in my build now. Been working on this for over a week. Its sucks but the time I take here is important. I have been using black primer sprayed on like just a light mist, to use as a sanding guide as I block it.
Good luck. I just made a mold of the side of the body (2 sides) and am extending it in the door area only , just 1-1/2" so entry will be easier..
