SHOCKS
I'm not an engineer, but I don't believe the bar would be strong enough not to bend from the force placed on it. Those bars are good for compression/tension forces.
But I'm sure someone has done it and survived....
iu
I am using a tube axle so maybe I can mount a brkt on the axle. I am doing spring over not the spring behind.
Can you use the type of mounts that go onto the bottoms of spring perch bolts? If they were turned inward?
