Size DOES matter.
tfeverfred
I found this tire size calculator months ago and it came in handy when I was deciding what tire size and rims I would need. It was made for fendered cars, but as you will see it is good for checking how sizes can vary. I got a pair of used tires that I thought would be close to what I wanted and then used this calculator to compare the measurements of what I wanted to the used ones.
It's easy to use and you can compare 4 different size tires. It also shows you the difference that size will have on your speedometer reading.
http://www.1010tires.com/TireSizeCalculator.asp?action=submit
when i saw the subject line, i figured someone had hacked your account and was using it to advertize...
Knowing thats not that case, thats pretty funny:)
:lol:Thanks for looking out, Nailbomb.
