Starting to run some brake lines
sstock
Should I use white sealing tape on the pipe threads?
Thanks,
Steve
Thanks,
Steve
Nope. Flares do the sealing. It it leaks you need to look at the pipe ends and their flares.
Gerry
I did put some sealant on my pipe fittings. I just made sure I put it far enough up on the fitting to help it seal but to keep anything from entering the braking system. I remember someone telling me at one time that a brass to brass pipe fitting didn't need any sealant on it but I've never tried it myself so I can't say from experience if that works or not.
Thanks guys for the replies. I know never to use tape on flares and I always use it on pipe threads but wasn't sure on pipe threads for brake lines.
