Steering drift
I will have to pick one up this week.
Here is what just found...I finally had some help and was able to measure the distance from the front spindle to the center line of the rear axle. The passenger side wheel base is nearly 3/8" shorter than the drivers side. Would that be contributing factor?
That wouldn't make it wander , would make it dog- track ....
I'm allowed to post pics now...may take me a while to resize some images.
Bias-ply tires wiggle a lot. When I changed to radials my car really settled down and was a pleasure to drive.
That would be a lot of wiggle...lol. I don't plan on changinging tires right away...these are new and not cheap. Do you think if I took off the wheels and tires and put on straight street radials on steel rims would be a fair test?
Oh, my, that is not good. Setting toe and other measurements are based on a straight frame with both axles perpendicular and centered on the frame centerline. If that isn't the case you'll go crazy chasing gremlins. Do what you have to establish this baseline geometry and then toe and such will be easy to check and adjust.
Sitting offset to the chassis doesn't mean jack , only thing that's critical is the axles be parallel ! Might look funny going down the road , but it will drive in a straight line ! Let me give an example , a few years ago we were going down the road slowly. (thankfully) when the left front spring pivot broke , the chassis sagged about an inch but the radius rods did not lit it hit the ground , the axle shifted about an inch offset to the frame but I was able to drive the car 5 miles to a repair shop , contracting all the way !!
Unless you lock the steering in the ( where the car goes straight ahead ) position (and I don't know how you'd do that accurately) measuring toe off the center of the car is pointless ....,I'm listening as to how / why measuring each wheel independently makes any sense ????
Point taken. The tires need to be straight ahead (90° to the axle) before setting toe to the centerline. Here is one way to do that:
rlh7YJ6jTVDl2lu6g80XPiVWD7xa7YSSFoiw-fsHrCZYtTbC_iz_Vxqu8X0O8N8qZlU7LosI7PZezfIgFAVVVc1H4qZpGs7E6kcEHZeVr3EjsONylGUIgAC-OXggMYw9UqPdEtvR2jKxBnleVNTrcuj1-D5owTgtVZCmPjTApqiRXf6mNUNu8ppoge57Q6tZHCFjqg0nMcWZbhx0iseWwbcyh1MFpZSCuHRsyt9tTm-hnbAZWWJW8nTJrySLMGxYCmF-2_ZL7xp8x9WyYMmfSkzAxwBnHDlTbe59OQVBzPVVdHIa2ymO-JTt4abq3WdQuJuPL2KaO4RhINBNK84FYBUQcxNQ5PZvtDdE2DhVvAkn56leIb0PSXY2VC7sK3g0q0p43z8TPZjWcJqPZ8z7F_MXhGGgRrcG4Hefwgkjzkw0ZCEsaLaaCwdzI3DNyTGqIqxg8XMWRMLuTtP7wj8jTtpbH__Xf7N2Lg6o0Ui425DyJE-AOPR4oa5lRTHMT5EgyYRMS9cfkokpS14Mr0jGuvXaa_8ah81W2TClsPW9ggUXSuIrEBQC6i5QJ3yCnxFy5499EcPBQm1x2EPJJnocPqP60m0j0wF51PJ34H_g7o57-AEeRBHIdIk34jedL_M=w1323-h612-no
When the A's are equal and the B's are equal, then the tires are parallel and straight.
Your example only accounts for having the kingpin pivot points square to the rear axle , because the tire/hub East pivots , the tires aren't necessarily parallel to frame or perpendicular to the axle , because of Ackerman , in order to set toe accurately , tires/hubs must be perpendicular to the axle and parallel to each other..
Something loose in the rear end can cause the car to wander as well. Check all that stuff too.
So what’s off, the front or rear axle?
The checked boxes are the tires. And this measurement will set them parallel and straight. This assumes the front axle is perpendicular to and centered on the frame.
Ackerman only applies to the steering arms, not shown in my diagram.
Messed up. Try again.
Seen lots of posts about toe-in/out settings, questions about how much caster , shimmy, wobbles, issues with bump-steer, and ruts/bumps in the road causing handling problems. I wanted to share my experience over last 230k miles, 27 years, numerous wrecks, 3 front axles, bent hairpins/radius rods, no front shocks for 20 years, numerous tires (heights/widths),... What I've found, many problems can be avoided if the bucket is square/straight. This allows the suspension and steering to work, but won't correct or hide poor design geometry. Don't like seeing dampeners or shocks used intentionally to mask or cover up problems. Also allows the bucket to brake and accelerate straighter, run faster, less unusual tire wear, and above all safer and more predictable handling. I'm not an alignment expert/professional but I have found this works for me. Course I'll assume standard straight front and rear axle and the independent suspension guys can modify these comments to fit their needs.
First, make sure the bucket is square (4 wheel alignment). Second, fix suspension geometry problems like steering travel, ride height, spring rates, shock function, suspension travel (watch how things move in an arch), heim movement or binding (use special washers), tightness and wear of parts, driveshaft angles,ackerman angles, ... Third, set the caster of the front axle. LASTLY: adjust the toe-in/out. I often see these steps done in reverse order (toe, caster, fix, finally align). Try not to skip Step 1. The following is my own process, uses very few tools, and works from the center of where the tire patch sits on the road (tire width and backspacing automatically taken into account). These instructions should compliment, not override, the Chassis information found in the Tech Pages.
Aligment step 1- Get it square and straight. Tools needed: 2" Masking tape, string, markers/pen, tape measure, straight edge/yardstick, and a plumb bob (plumb line), a small amount of paint and paper to write measurements (or use the diagram I created in powerpoint).
Find a clear, flat surface to work (garage floor, concrete slab,...) and enough room to drive straight onto this surface. drive the bucket straight in without turning the wheel. Once you feel comfortable that the bucket is sitting straight put it in park-- do not touch the steering and set the emergency brake/chock tires to keep the bucket from moving.
Place a piece of masking tape on the floor, at the front and back of each tire (centered). Front tire example:
Rear tire example:
Note: Precision in finding the center of the tire is crucial to placing the plumb bob (my tires have a centerline groove which makes it simple). Also try to take measurements within a 32nd of an inch on the tape measure.
Next, dip the tip of the plumb bob into the paint, so it will leave a small dot where it touches the masking tape. Hang the plum bob down the center of the tire like this:
Make sure the plum bob hangs straight down and doesn't swing/spin. Slowly lower the plumb bob till the tip touches the masking tape on the floor and leaves a nice little mark. Do this procedure to the front and rear of each tire. Do not rock or move the tires.
After all the tires are marked. Take a break while the paint dries on the masking tape. 15 minutes should be enough time to read the rest of the instructions and prepare.
Back the bucket out of the way. Should have 8 pieces of tape on the floor (front and back of each tire) and each one have a small dot. In picture, the red and black pens indicate the dots on the tape.
Place another piece of masking tape down, connecting the 2 pieces already on the floor. Should look like this
With a straight edge yardstick, draw a line connecting the paint dots (in this picture from the black pen to the red pen). Measure the distance from dot to dot and divide by 2 and put an "+" at that point (location of green marker). This is the center of the tire where the rubber meets the road.
Do this procedure for the remaining tire locations. Should look like this:
Place a piece of masking tape between the center marks "+" of each front tire and the rear tire. This will represent the axles so we can find and mark the centers. Should look like this:
Tape a string (unless you have a straight edge that's 6 feet long) to the floor, from the center of the front driver's tire to the center of the front passenger tire. Measure this distance and divide by 2. Put a mark "+" at the exact center of the axle. Do this for the rear also.
Here's the part where a friend, wife, buddy really helps out. Record all the measurements indicated by the diagram. Lots of measurements but will give you lots of information about your alignment, thrust angles (acceleration/braking), wheelbase, toe-in/out, and could also let you know if the rear axle housing is bent. Be precise on these measurements.
Now for the VISUAL stuff. Tape a string to the floor from the center of the driver's front tire to the center of the passenger rear tire. Then tape a string from the center of the passenger front tire to the center of the driver rear tire. Finally, tape a string from the center of the front axle to the center of the rear axle and find the center (length/2) of this string and put a piece of tape on the floor underneath the string and mark "+" this spot. Should look like this:
If the bucket is square, it should look like this:
Notice the cross "X" strings are just above the center mark "+" of the axle centerline. Because in this example, the centerline of my rear tires are wider than the centerline of the front tires. This is ok in this example since the crossed "X" strings met directly over the centerline string.
Make small adjustments to correct any problems and only make one or two adjustments at a time. When making adjustments, counting threads on a rodend or heim can get you real close (12, 16, 18 threads per inch). Put a date on the Diagram and make a note on the changes you made (example: front passenger hiem on radius rod unscrewed 2 turns, rear panhard lengthend 2 turns).
After making adjustments, drive the bucket and see if the adjustments helped. Then start this procedure over again. Record your new measurements. It may be somewhat time consuming but can avoid or solve many other problems which may save $$ and avoid other issues. Try not to skip step 1.
Sorry for the mix up. My head aint quire right today.
Rear tire example:
Excellent description for a newbie...much thanks! I am going to work on that this week while hurricane Florence has me stuck in the garage this week.
#37 Kurt64, Today at 11:47 AM
Not mine but Tim/Toolman from NTBA site.
Ackerman
  • Ackerman Steering - National T-Bucket Alliance.txt
All this is just fine , has 1 huge flaw : taking measurements from and using TIRES as reference points , tires are simply not true enough or rigid enough to get accurate , repeatable measurements ..,.
It's true that tires may not be the best for taking measurements, but its probably the best way to get a relatively accurate alignment without having to spend a lot of money for some measurement you may never use again.
Just sayin'.
