Gerry
With the brackets finished and ready for final installation it was time to turn to my somewhat dubious plan to eliminate the tie rods from the frame to the chassis.
The flat bar that extends backwards and along the top of the body was added to help transfer some force to a much larger area. The joint between this bar and the brackets needs a fillet to be any good, which will be screwed in at a later time.
So here goes. A vertical 'post' was welded to the top bar and bent to conform to the curve in the body. I could have just glassed it in, but that meant the screen would become a permanent fixture of the body.... no a good thing.
I needed to captivate the vertical bar so there was no movement but make it easy to remove. Spreading the load was also a requirement so I came up with a triangular frame that holds the side to side movement and a small tab at the bottom to stop the possibility of the bar 'stepping out' of the frame. Again the frame was bent to the form of the body. X 2 and we have both sides the same.
A dusty 20 minutes later and the area around each frame had been ground to accept the glass fibre which was going to fix the whole assembly to the body
A bit of messy fun with some matt and resin and the job is done.
The addition of a triangular block between the bracket and top piece of flat should strengthen it up, but I can only do this after the interior is being sorted out. The blocks will also serve as a pin and hole location for the top flange and roll of the interior which I want to be removable for the future top I have in mind.
I have no idea if this will work, but I thought I would give it a try. It didn't take too long so nothing to loose.
G
G
