OK....here my head goes again!!
I'm determined to get a nice low seating profile in my T project. From what I can dertermin on my end...I need to extend the cowl about 8" to give me the leg room needed using a "STANDARD" body that can I can get from TP (hop, skip and jump from my home).
Next thoughts are to get the body 4" to cover the frame rails and to give an overall lower stance to the vehicle.
Frame thoughts are to keep the front pretty much "STANDARD" as other "T's"...1.5 x 3..but angle the frame out from the firewall to the back of the tub following the lower outside body line to eliminate the frame interfering with seat position/height. From the back of the tub the frame will be pulled back in and continued with a 10-12" drop.
Will install a pick-up bed on the rear....thinking about the MAS 30" one.
Also thinking about a solid fiberglass roof. LOW to give it a chopped top look. roof will be hingged to allow access into bucket then latched down in place once inside. It will also be removable.
Now these are just so random thoughts .....Any tips...tricks...advice?? Thanks!
