Hackerbilt
Hey guys...having what I thought was a weird problem with my T.
Had the axle jacked off the floor for oil change clearance and the tire felt loose. Rocked back and forth like the KP bushings were bad.
They are only 2 years old.
Had a closer look and the problem turned out to be KP slop in the axle end!
Ok great...so pulled everything apart to see what was happening to wallow out the hole and it seems perfect. The hole isn't wallowed out at all...its just big!
I believe the setscrew backed off and allowed the KP to simply flop around.
Seems very weird to me that the pin is so much smaller than the hole.
Shouldn't they be a push fit thru the axle hole?
I'd guess I have .010" clearance around the pin! It just drops right thru!
Is that normal?
Seems like a lot is being asked of a single setscrew to lock things up tight if thats the normal way....
Is that normal?
