PlasTque27
Hey guys, new to the forum and will probably have a few questions during the build of my '27 Roadster. I've done a lot of looking and have already learned a lot!
I was able to find a guy locally that makes bodies. This thing is incredibly thick and stout. Only problem is there is no lip around the bottom of the body to make adding a floor easier like on the Speedway bodies. The sides are cut straight down if that makes sense.
I am not going to channel the body at all as I want to sit as low in the car as possible. Now thinking about the floor, the guy I bought it from recommended raising the floor up an inch of two so I can glass both sides of the floor to the body.
My question is, can I lay the bottom of the floor flush with the bottom of the body and just glass the top side of the floor to the inside of the body really well?
I plan on using 5/8" plywood for the floor if that matters at all. Thanks in advance for any advice or suggestions!
