Mike
One of the more overlooked tools for engine diagnosis is a vacuum gauge. It can quickly and easily identify internal engine problems, but many people don't have a clue how to use one. And that is the purpose of this article, to clear up the mystery surrounding how to use a vacuum gauge to help you tune your ride.
One of the first steps in using a vacuum gauge on your vehicle is to have a pretty good idea of what vacuum levels you see when the engine is happy and running normally. A stock engine, when all sealed up, will show vacuum levels as high as 18-20 inches of vacuum, whereas a highly modified engine with a lot of camshaft can show much lower levels. When you are sure you've got your new engine sealed up and dialed in, stick a vacuum gauge on it and record what you're seeing as a stable reading.
An engine in good condition should show fairly consistent vacuum levels at all stable engine speeds. If you rev the engine 2,000 - 3,000 RPM over idle speed and release the throttle, you should see vacuum jump anywhere from around 2 - 5 inches over your normal numbers and then quickly snap back to normal.
If you notice a consistent drop of about 2 inches of vacuum from normal, you've likely got some slightly retarded ignition timing.
If you notice a consistent drop of about 5 - 10 inches of vacuum from normal, retarded valve timing is likely the culprit.
If you see a consistent drop of 10+ inches of vacuum from normal, it's time to find the leak in the intake tract. Carb base gasket, warped intake, cracked intake, manifold gasket leak or a bad vacuum hose are some of the probable causes.
If you see the vacuum level dropping steadily and rhythmically, then something is happening in a single cylinder. It could be a bad distributor cap, a bad plug wire or a bad plug. It could also be a valve that is not seating properly.
If you see a very intermittent and rapid drop that will just as intermittently recover, you've got a valve guide trying to grab a valve and keeping it from seating normally.
If you see the vacuum level rise 2 - 5 inches on rapid deceleration, but the gauge slowly returns to normal, start looking at the exhaust system for a possible restriction.
If the vacuum level doesn't rise much on rapid deceleration, then it's time to break out a leak-down tester to check piston ring seal.
If you see the vacuum levels continuing to fluctuate 2 - 3 inches either side of normal, you probably have enough worn valve guides admitting air to the port and giving the carburetor fits.
If the vacuum gauge seems to lazily change at idle and then get stable at a higher RPM, you've likely got a shot valve or a blown head gasket.
If you see the vacuum level continuing to vary at a steady RPM, it's time to start tuning. If you're running multiple carbs, they're not properly balanced. Ignition timing could be off or plug gaps may be set too far away from what makes your engine happy. Or you could have some bad valve settings.
If the vacuum level is fluttering back and forth at idle but flutters in a narrower range at a higher RPM, you likely have a leak in a manifold gasket.
If the vacuum level flutters back and forth at idle and gets worse at a higher RPM, start looking for a broken rocker arm, a bent pushrod or a broken valve spring. If everything appears to be in good shape, get some springs off and check them for load.
If the gauge makes slow and steady flutters, matched by a change in engine idle RPM, you are either looking for a very minor leak or your idle mixture settings are off. A quick tip here is to work back and forth on the mixture screws, adjusting them for the highest, steady vacuum level.
If you're running a Holley carburetor and notice vacuum levels fluttering, engine RPM hunting and seeking and a definite gasoline smell at the exhaust, the power valve in the carburetor is either blown or wrong. Once you get a good valve in the carb, a quick tip to determine the best power valve choice for your application is to note your lowest vacuum figure at idle and your lowest vacuum level at a steady cruise RPM on level ground. Those numbers should be very close to one another, but take the lowest number and select a power valve about one to one and a half points below it. For instance, if you record a low number of 10 inches, select an 8.5 power valve. That will prevent the valve from sneaking open on you during idle and steady cruise RPMs, but it will also position the valve to tip in quickly when you need it.
I hope this will help some of you, the next time you're trying to diagnose a problem or just tuning for maximum efficiency.
