White T II
Is that an entire torch assembly or just a remote wireless amp controller. Undoubtedly my 1967 Lincoln 300-300 Idealarc Will not be a doable deal.
It is a remote amp controller, just like a foot pedal, but it is not wireless. I have mine hooked up to an old Miller 250 DX that I bought before inverters came on the market. The frame that I am working on is about 12" off the ground so I am crawling around on hands and knees to weld brackets in place. I have been using the button exclusively, so much better than a knee or elbow on the pedal.
It's the same TigButton 409T has. I just removed the button form it cas and installed on a CK FlexLoc torch with shrink tubing. To use the Tigbutton, you would unplug the black/yellow wireless controller for the foot pedal and plug in the connector to the left of it, with the small grey wire, in its place. I read somewhere that they have made some Tigbuttons for special applications. I don't think it has to be an inverter style welder. It's great for welding inside a dragster roll cage.
Forgive me for jumping in on your thread. Here's another brand showing how they work.
I'm not really thrilled with the front panhard bar placement, but I couldn't think of any other way to do it. At least now the engine, trans and radiator are all located and bolted in.
Panhard looks fine and not many choices. I might be a bit concerned with drive line angles. Would like to see straight on photo from either side.
Do you have an I-beam and trolly running across your ceiling?
Looks like a nice set up.
I know what you're saying but at the moment I'm not too sure what I can do. The drive lines in our other two T-buckets are pretty crooked also and they have survived, but I know that isn't the correct idea.
I am going to use a left over deuce radiator that has been cut down 3". I don't want a deuce radiator shell, a Model T one doesn't fit as well as I would like so I bought a Model A one from CCR and cut it down 3" in height. I decided that I wanted it to be an inch or so deeper so that it would better cover the radiator, this meant adding to the rear lip of the shell. First I cut a piece of Formica to make a backer inside the shell and covered it with masking tape so that it wouldn't stick to the resin and mat that I am going to put in.091947_re.jpg 091957_re.jpg Next I spring clamped the Formica into the back side of the shell. 162043_re.jpg 162037_re.jpg 162022_re.jpg The last thing was to start putting layers of fiberglass mat onto the Formica backer. 100928_re.jpg After I have enough layers of mat to reach the desired thickness I will add one layer of glass on the front and back to hold everything together.
That's some impressive bending.
Do you have one of those roller type coil straighteners?
