Youngster...Think it would work?
ruggs
[/IMG]
I was thinking about using this pedal set-up but flipping the bracket over and using a remote system under a fake cowl vent. This would be on my C-cab that I'm extending the cowl
I don't know if clutch master and brake master run same pressures so definitely switch masters also. Should work though
Is that a Wilwood setup? Why don't you get the under cowl mount one if that's the way you are going to use it. The under cowl mount is a 7:1 ratio vs a 6:1 for the floor mount. I don't know if they have a clutch/brake combo for under the cowl mount thou.
I don't see why it wouldn't. Might have to get a little creative with the mounting but then that's just good rodding pratice.
