rooster57 said:Remove the temp gauge from the housing it must have a pos input on it somewhere and the single post is the sender input from the gauge do you have an ohm meter??? if so check for resistance from the center post to the case. Should be no continuity The input from the sender is usually a high resistance ground. And as the temp rises the ground resistance changes ,so apply a small voltage to it like 1.5 volts from a D cell battery or a 9 voly battery. if their is a problem your less likley to have a big arc with a small battery and its pleanty of voltage to operate a gauge.
The break on mine was very clean, I personally know the idiot that broke itrooster57 said:I first thought that also but the tube if broken off is VERY smooth break. I thought all these early 50 were the bourdon tubes to the block. But i had a 57 chev pickup and it had a factory 6 volt gauge. When i converted to 12 volt i had to use an aftermarket temp gauge.
