There was a seminar at the meet about tips and tricks. One I thought was interesting was about cut-off wheels. Most all of us know they cut best in a forward motion. By trying to cut while backing up you are mostly jus waring your disc down faster. What most don't concider is they are designed to cut at 20,000 rpm. When you use one on a air die grinder, you might be turning 20,000 rpm at first but as soon asyour air pressure drops, so do the rpms causing more ware on the disc.
Concider this, an electric die grinder turns 20 to 25,000 rpm constantly! You can make your cut without waiting for the air compressor to catch-up, your disc will last longer and you will make the cut faster. A comment was made that electric die grinder are much more expensive than the pneumatic type. This is true but for the hobbiest, Harbor Freight come to the rescue. $35 and you too can be the proud ower of a fine piece of equipment. If you do a lot of cutting, the savings alone in disc's and elictricity make this a viable option. I would agree there are times when an air type will best do the job especially one with a 90 degree head but for all other cuts....
