Awesome Railroad Thermite Welding Process You've Not Seen Before
we called it cad welding, it is the only way to weld rebar. with cad it leaves a sleeve that the melted metal runs down into.
I think it uses the same principle as the termite grenade we had in Vietnam. All Top Secret files kept in a fafe had one sitting on it. In the event you were being overrun you just pulled the pin and it would burn through the top, all shelves and the bottom almost before you could get out the door. Artillery crews had them to burn though the breech is being over run. And sometimes us helicopter crews carried a couple along with some frags just in case we wanted to get playful.
Wouldn't mind have a few now as I think about it!
