Gerry
Moved this away as it was off subject to Northstar.
Where do I start. Our 3.5 ltr V8 Rover is the most used engine in hot rods in the UK. It was certainly the staple for Anglia s, 32s and Ts in the 70, 80 and 90s. Why? because they were plentiful, not TOO big, light, and cheap. American V8s were harder to find and in a lot of peoples mind, did not have a power advantage when off set with the extra weight.
I know that my buddy who was running a SBF and cracked the block on a cold night (no antifreeze Huh!) replaced it with a Rover and said it was faster.
Rover engine are now very rare and well sough after and a whole aftermarket has sprung up around then The now offer the old 3500cc Rover up to 5200cc. in various stages of ever increasing capacity.
When John and i were playing around a lot more with cars for ourselves and other we had around 15 of these engines sitting in the shed all waiting for a home. Everyone of them needed hydraulic followers replaced and camshaft bearings done, it was their weak spot. At that time each follower was £4.00 (probably close to $7.50 at that time) so a full set of 16 meant a sizable investment.
I will try and fish out a few pics of cars with them in.
Yep they did a EFI version in the standard car... very rare and the of course the Turbo beast.
The Audi engines are a FORTUNE even from a breakers and with the modern CanBus system I think you would need to be a electronics wizard to get the engine to run in something else. Even the instrument panel in the Audi had inputs and outputs to the Engine mapping, not to mention the AC, ABS, EPS, Audio system, headligh adjusters etc etc. But it is a monster with torque to die for.
Gerry
Gerry
