I have a set of sprint style headers and would like to run a 90 degree turn out right after them. I was thinking of putting baffles in the header tubes themselves, either in the straight tubes coming of the heads or trying to get them in the straight part right before the collector. Anyone ever try this? Would the baffles being so close to the heads cause to much back pressure or anything else?
I have headers like these:
http://www.speedwaymotors.com/S-B-Chevy-Sprint-Roadster-Headers,3835.html
I was thinking baffles like these (one for each tube):
http://www.jcwhitney.com/internal-baffles/p2006266.jcwx?filterid=j1
The baffles you refer to are for bikes....they really don't quieten things down any, they kinda take the bit out of the sound.
The extensions with turnouts worked good in the past, with the auger type baffles with steel wool packed in there. I'm deaf anyway....so the noise doesn't bother me....Haha....
I like the internal slip-in mufflers, like what Ted ran, but thats me.
I've always had good luck with 3 in collectors, add about a 12" extension. I cut 2 pieces of 10 ga.SS sheetmetal the size of the ID of the extension, with a 1 7/8's hole in the center. I usually make things out of SS, so it'll last. Then I roll a 1" wide band, or a piece of tubing that'll just slide into the the extension, I roll a piece of (1/2") expanded metal, the size of the hole (1 7/8's) X 8" long, then have the other piece at the back. I weld it together, around the expanded metal core, I loosely wrap some asbestos packing, and wrap that in SS wire, so it won't go anywhere for a while. I then insert said piece into the extension about 3 inches from the end, then drill thru the extension into the band/pipe lip on the front of the baffle.
I've had pretty good luck out of these....they only last about a year, then you have to repack it usually. If you don't run it everyday....it should last a few years....but the SS will be there for the duration.
My hearing went out about 10 or 15 years ago when I started a Nitro Nostalgia digger, warming it up, pulled the alky line out of the tophat to run on nitro, plugged the hole, reved it to clear it out, set the idle speed on the linkage, had my ear a little too close to the zoomies when I reved it that 2nd time. FROM then on....I've never had to worry about too loud of a exhaust note! :blush: Ha!
