Wow! That IS a tiny battery. That would definitely provide more options for sure. How does it crank the engine? It seems so small...I haven't gotten a battery yet, but if that will work, that would be great!What size battery are you using? If you use one of the small gel batteries your options open up.
I mounted mine between my crossmembers:
Thank you!Odyssey PC680
