I try to keep track of part numbers that are posted, I have a "address book" that is Alphabetized that I keep the notes and part numbers in. Saves time looking for a scrap of paper in my wallet everytime I need a part number or someone askes a question..
Here are a few Brake Part Numbers and maybe a note or two.....
"BH"
Master Cylinders...
NAPA # 37039, 7/8" bore
NAPA # 39004, 3/4" bore (Vega)
NAPA # 36440, 7/8" bore
Raybestos M/C 36300, 3/4" bore (73 Vega w/o power brakes.
Ford Fairmont 78-81, 7/8" bore
M/C Notes: For Drum systems try M/C from 73 Dodge Dart.
Brake Note: The fittings for the Vega M/C's are kinda hard to find (atleast for me) separately...Here are a couple part numbers for "adapter tubes" from NAPA. These are short pieces of brake tubing with the nuts installed and flared...Buy the adapter tubes, cut off the flares and use the nuts... :neutral:
NAPA # 813-1155 ,3/16" tube,Small Thread
NAPA# 813-1158 , 3/16" tube,Large Thread
DUAL Master Cylinders ( hyd clutch/brakes)
Raybestos part # MC36155 ( International truck , 1"bore,4 bolt flange)
Raybestos part # MC34404 ( Chevrolet truck, 1 1/8" bore, 3 bolt flange)
Raybestos part # SC 19097, (Hyd. Clutch Slave Cyl.)
Here are some handy links for Pedal Ratio and other Brake related items:
Brake Pedal: The number one cause of a very hard brake pedal is pedal ratio.
Brake trouble shooting
BrakeCylinder.com--Odds and Ends
http://www.stoptech.com/tech_info/PedalSetup-DualMaster-Guide.pdf
Mark Williams Enterprises - Brake Technical Information
StopTech : Balanced Brake Upgrades
I hope this helps you out.......
"BH"
Master Cylinders...
