Well, I am new even though I've been lurking around for a while and Iam trying to get a feel for this place. I will post picts soon, but I am building a 27 RPU and will be building the motor soon. My question is, how many of you have flatheads and have building knowlege that you could share with me? My 8ba is out of the machine shop and I have a lot of books bought but no locals are still around to help build the thing.I live in San Angelo, Texas and can use help.....THANKS, MAN!
Pay close attention to what Younster told you in that lastpost.....he's a great guy sharing all his great info!!!!!
Yes....descale that block all you can.....I'm a terrible person to watch when I do it cause
1. I hottank the block....
2. Then I do the poking thing at the deck openings....there's a lot of restriction there....let her dry a couple of days to dry out completely....
3. Then I fire up the sandblaster, and down in the passages I go....when I see fresh graycast....I stop.
4. Then I spend several hours of purging all the sand from the waterjacket, flushing and bsck flushing till theres no grit at all coming out, with my high pressure washer.
5. Then I blower her out with 150 PSI of compressed air.
When I think I got her done.....I pressure wash it a second time and blow her out.....I am a stickler for that grit....then were off to get her worked on....
A big deal with flatheads is sometimes the gaskets can 'shroud' some of the coolant holes.....it you can't see the edge of the block cause that gasket hides part of it.....match the gasket to the hole. It doesn't hurt to open the coolant holes up a little, if they're really small and you have a good bit of meat there.
Now don't get carried away, especially if your by the bore.....cause you could cause a crack or water leak there.....
As Youngster said.....there are alot of good books about building the flatheads....and you canget alot of respectable performance outta them if done correctly.....
Now, after your machining and boring is completed.....wash that engine agian under high pressure, get everything thats not metal off and out of that block!
As soon as your baby is out of the final wash....get a cheap pressurized hand held garden sprayer filled with SAE 30 wt oil and spray her down all over and wipe it everywhere with a lint free cloth. then slide a 40 gallon trashbag over her....tie her up in it until assembly.
Yea.....its a little overkill but I've built about 10+ motors in the Nostalgia racers ranks and not a one has overheated. And don't forget to include a hiflow waterpump on that engine and a oversize radiator.
