skullman
Hi guys. My bucket is finished and have it on the street, but I'm having some carburetor issues that are taking the fun out of driving it. The car will fire up and run like a bat out of h - - - first thing in the morning and will run and start all day long as long as I don't let it set for more than 10-15 minutes. It I start the car within 10-15 minutes it will fire immediately and run great . . . but if it sets for 30-45 minutes I have to crank and crank and crank before it will start. Pumping the gas pedal or not makes no difference. Once it becomes hard to start it will continues to be hard to start until it is completely cools . . . like overnight. Also after you have cranked and cranked to get it started it runs like a champ again and the whole process repeats itself. I have talked with Edlebrock's tech guy several times and he can't seem to help me. The engine is a fresh 350 with brand new Edelbrock 1406 carb on Edelbrock Performer RPM manifold. Everything is new . . . mechanical fuel pump (with pressure rating of 5.7-8 lbs), spark plugs, wires, Pertronix Ignitor and Pertronix coil, fuel filter, steel fuel lines, wiring and 14" x 4" air filter. Is there anyone out that who has experienced this problem and can help a frustrated old hot rodder enjoy his ride?
